Inj all 17ohm can still be bad?
Old Dec 14, 2013 | 06:23 AM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
I have a 8 lb9 sat for probably 8-9 years looks like original injectors but probably replaced 10+ years ago and were not run.
PLugs connectors look and when hot they all ohmed exact;y at 17.4-17.6 seemed off they were all so close.
Just starting tuning and dataloggin I will run today so far it appears I have 140-160 BLM at idle I will see what drive it like but I know it bogs at throttle and no power
I checked plugs they look ok, black at bottom and brownish along arc with little white at tip
Old Dec 14, 2013 | 07:39 AM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Re: Inj all 17ohm can still be bad?
Anything 15 to 17 is healthy electrical wise. Try some Seafoam injector cleaner, wonderful stuff. Sometimes you can get a 2 pack for $13 at walmart or Napa. OHM test wont show if they are clogged or gunked.
I just put a fresh set of Bosch III's in the Camaro, what a difference. Had 3 out of 8 ohming below 12, one was dead, .004 .... smooth like a caddy now.
Old Dec 14, 2013 | 07:53 AM
jjcuff1's Avatar
Yes I figure they might be clogged the fuel pump and tank were so bad the mechanic said he back flush replace most of the lines and all new tank and up
Pump. Was hard and orange the old gas
So maybe they are shot and explain lean condition
Also I notice after running up to temp I am seeing fluid leak on floor but it looks and smells almost clear not gas or tranny
And it is not under rapidly but by back of engine or under tranny and sems like water since it puddles far away it is begone my car not I. Front
Is this a rear intake manifold coolant leak
Or head gasket leak?
Old Dec 14, 2013 | 12:44 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
KCG
Jun 24, 2020 04:33 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
gta892000
Sep 16, 2015 12:40 AM
