rich running.
Old Dec 14, 2013 | 07:38 PM
fusion's Avatar
rich running.
hi I got a 91 z28 5.7 tpi it is running rich when its cold it will crank once and start most of the time but when it is warm it will crank for about 30 seconds and start and then have a really bad fuel smell. I have to have the pedal to the ground so it starts easier. I have a new CTS and MAP sensor and also have a new fuel pump because the one in it right now makes a lot of noise. the car while driving will back fire after letting go of the pedal at higher rpms too. any suggestions on what the problem could be?
Old Dec 14, 2013 | 11:50 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: rich running.
I'd guess a leaking injector(s). Access a FP gauge and see if the pressure drops real quickly after shutting it off.
Old Dec 21, 2013 | 02:56 PM
fusion's Avatar
Re: rich running.
I tested the fuel pressure with key on but engine off it would hit 40-42 psi then start dropping. but with engine running it would stay at 42 psi then when turn it off it drops pretty quick. im kinda thinking regulator. any thoughts?
Old Dec 21, 2013 | 03:16 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: rich running.
When the fuel system goes through the 2 second prime it should hold fuel pressure for atleast 5-10 min before it slowly bleeds down. If you pull the fpr vacuum hose and have evidence of fuel the diaphragm is torn. Bye pinching off the jumper line on the return side. That is the 5/16 line coming off the fpr. at he fuel pressure will hold longer unless you have a torn diaphragm or leaking injector or its bleeding back through the pump or pulsator.
Old Dec 21, 2013 | 03:32 PM
fusion's Avatar
Re: rich running.
as soon as the fuel pump kicks off it starts dropping and only takes about 30-60 secs to hit 0
Old Dec 22, 2013 | 11:28 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
Re: rich running.
Had similar prob (w/o the smell tho), and it cleared up when timing was set to 17 degrees.
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
Jonas Earl
Sep 27, 2015 07:39 AM
89fast5oh
Sep 8, 2015 09:55 AM
Jk_Under
Sep 8, 2015 08:13 AM
