FIXED remove stock fuel line/male plug cold start?
Old Dec 31, 2013 | 09:40 AM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
I have the upper pulled off my 88lb9
I pulled off the cold start. But with the hawks cold start plug kit, I am thinking it ont plug the fuel rail? I have a plate for the runner and looks like 13mm ss threaded bolt. The end of the fuel rail is not a female though?
Anyone use the hawks cold stat plug kit on stock fuel rail?
Also I have the stock lines that connect at the bracket under the alternator. It was a beatch to unscrew with a flare wrench but I think they are loose. But hard to pull free from inside the line (like a swagelock) and the bolt to un screw the flange is behind the lines, seems unreachable?
any tips how to remove the fuel lines safely form the fuel rail and bracket?
Fixed: Well after removal of the fuel rail there is double sided male plug in the fuel rail. It was on tight I had to use a breaker bar and large adj wrench but once I did the Hawks plug goes inside the femal thread no problem
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
