New intank pump
Old Jan 25, 2014 | 09:40 AM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
New intank pump
Hi!
Need some advice,i am about to installa walbro 450 pump and its a little bigger at the bottom so any suggestion how to modify it best way ?
Old Jan 25, 2014 | 03:40 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: New intank pump
Yeah...don't, that pump is way over kill for anything needed.
The regular Walbro is also way over kill (90 gals, per hr.)
The EP 381 AC Delco works best for up 450HP
Old Jan 26, 2014 | 03:11 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: New intank pump
Ok
The new stroker is built for 500fwhp,the fuelpressure drops to 20psi over 4500rpm and lean out.
So i bought a walbro 450 for E85 sense the engine is made for ethanol.
Could it be somthing else cousing that pressure drop ?
I have change filter,maybe the stealthram fuelpressure regulator.
I am alsoe going to install at airomotive fpr and a Y fuelrail split.
What can be wrong by installing as you say, a overkill pump ?
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
