Color wire
Old Jan 29, 2014 | 09:46 AM
Txwildman's Avatar
Color wire
Hi ya'll newbie here!! I have a 91 formula TPI and one of the fuel injector connector broke. I am looking on ebay for a new pigtail but the color of wires aren't matching. My tpi Fuel injector connector wire colors looks to be 1 green wire and 1 brown with black stripe wire. On ebay the colors are 1 green wire with 1 pink and black stripe wire. Does it matter the color of the pigtail wires aren't matching? The one on ebay is a different color. Or should I just stick with the color wires that's on the my engine already? Any info ya'll can provide is appreciated thanks.
Old Jan 29, 2014 | 03:22 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Color wire
Power is not going to be concerned what color the wire is
Old Jan 29, 2014 | 05:21 PM
Txwildman's Avatar
Re: Color wire
Cool just wanted to make sure I was getting the right pigtail I already ordered it thanks.
Old Jan 29, 2014 | 06:40 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: Color wire
Sure it is! Electrical current doesn't like green wire. Now the color of the wire's insulation doesn't matter.
* For the humor-impared, "green wire" is corroded copper, which is a problem.
Old Jan 29, 2014 | 08:09 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Color wire
Not sure what is broken but you can sometimes repair what you have, or if the clip latch is broken then you could pull your wires out and slip them in the new connector. Check out your local junkyard, you should be able to get something similar, possibly even from a different car. Just make sure that the wires are the same gauge (thickness).
Here's a random vid I found explaining it:
If you do splice wires instead, try to stagger them if you can so you don't get a lump in one spot. This also helps ensure that they don't ever have a chance of contacting each other.
From here: http://www.electricneutron.com/wirin...uctor-splices/
Old Jan 30, 2014 | 09:00 AM
Txwildman's Avatar
Re: Color wire
Thanks for the video and all the info it's really appreciated.
Old Jan 30, 2014 | 11:50 AM
Scorpner's Avatar
Engine: V6, V8
Re: Color wire
Glad to help!
Linson
Aug 21, 2015 02:12 PM
LT1Formula
Aug 20, 2015 09:36 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
87350gtanj
Aug 8, 2015 10:32 AM
