upper plenum difference question
Old Mar 4, 2014 | 06:27 AM
ssj2link's Avatar
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
i have a quick question, just picked up an 89 upper tpi plenum and i want to install this on a 91 tpi. is this going to cause an issue? some people say it will work fine others say no because its missing the spot for the sensor on the back??? can i get some clarification please? whats the differences? what sensor is that exactly
Old Mar 4, 2014 | 07:23 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Re: upper plenum difference question
There is an added port at the passenger side rear of the 91 for the MAP sensor. The MAP sensor needs it's own port so that it can read the manifold pressure (vacuum) correctly. You could "T" the other vacuum port for the other two vacuum lines.
While you have the plenum off now is a good time to match the runner ports on the plenum to the runners. The plenum on my 87 bird had about 1/8" of material extending past the runner port on one side and the two halves were not aligned very well making the top portion of the circle offset from the lower portion. I gave it to my brother for his 86 IROC and without any other changes it did improve his performance a little bit
Old Mar 4, 2014 | 03:51 PM
ssj2link's Avatar
Engine: 5.7/5.0
Awesome thank you very much!
Old Mar 4, 2014 | 04:38 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Exactly the same as when guys do MAP conversions on MAF engines;
remote mount the MAP sensor and run a line ( as short as possible for best response ) to the intake vac port
evilstuie
Jan 9, 2020 08:29 PM
fasteddi
Sep 2, 2015 10:29 AM
TheExaminer
Aug 26, 2015 04:59 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
