TPI Harness
Old Mar 8, 2014 | 02:39 AM
IronEagle455's Avatar
Car: 91 Firebird/92 GTA
Engine: 9C1 350 TBI/L98 TPI
Axle/Gears: 3.42 Gov-Lock/3.23 Posi
TPI Harness
Ok, here it goes, I recently bought a 91 Firebird with the L03 TBI 305 engine, the car has given me some problems(erratic idle, stalls), I´m in the middle of diagnosing it, I noticed if i unplug the MAP it idles better and wont stall, but that´s another story.
What I would love to know is how hard it is to change from TBI to TPI, a guy is selling me the complete TPI intake, throttle body, fuel rails, fuel lines, injectors, etc, he also has the ECM and the wiring harness, the problem is he mentions the wiring harness may need some plugs changed, he has a spare harness form a 89 and will add it a no cost, so, how hard is it to do the changeover?
I tried the search button and as far as I understand, itps just a matter of unplugging my harness and plugging in the new one, changing the knock sensor and adding some fuel lines, as far as I know I can also just connect my vats to this PCM and have no problems, right?
This would be my first experience with TPI, anything I should check before I go out and buy the TPI system?
Any help is greatly appreciated.
Old Mar 8, 2014 | 05:53 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TPI Harness
Read
https://www.thirdgen.org/tbitotpi
Note the 2nd line
"Before you start I will warn you this is a major change to your car and will take a lot of work and time".
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
IBrockZ
Aug 20, 2015 12:20 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
