Which FPR, O2 sensor, and gasket kit?
Old Mar 15, 2014 | 01:29 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Ladies and Gents,
I'm the proud owner of 1991 GTA with a 350 TPI. My motor is mostly stock. But, I have aspirations of future mods (heads, cam, etc.).
I'm about to pay my mechanic to replace my fuel injectors with Bosches.
While I'm at it, I'm going to install an aftermarket fuel pressure regulator. I've heard bad things about Holley. Can anyone recommend a brand/model?
Also, I'm installing the following Fel Pro gasket kit.
http://www.southbayfuelinjectors.com...5-0l-350-5-7l/
Are there any other gaskets that can be replaced while we're in there?
Additionally, I have a bad O2 sensor. Can you recommend a good replacement?
Finally, should I take this time to do any other upgrades or routine maintenance on my motor? Is there anything else that should be replaced while this stuff torn apart? Should I replace or upgrade the fuel rails? (Will a virtually stock motor benefit from upgraded fuel rails or a fuel pressure regulator?)
Thanks for your help!
Bill
Old Mar 15, 2014 | 02:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Which FPR, O2 sensor, and gasket kit?
Southbay for a stock diaphragm, bosch 12014 on ebay, cleaning out your egr and passage while the plenum is off. Felpro on the gaskets would be my choice.
Old Mar 15, 2014 | 06:03 PM
wgripp's Avatar
Tuned Performance,
Thanks for your feedback. Regarding the gaskets, I already ordered Felpro. I'm just wondering if there are any other gaskets that I can replace that aren't included in the Felpro kit I ordered.
Thanks!
Bill
Old Mar 15, 2014 | 06:05 PM
wgripp's Avatar
I'm torn between the SouthBay injectors AFPR and the Breathless performance AFPR. Any thoughts?
Breathless...
http://www.breathlessperformance.com...&productId=844
SouthBay...
http://www.southbayfuelinjectors.com...tor-diaphragm/
Old Mar 23, 2014 | 11:56 AM
wgripp's Avatar
Ended up getting the following parts...
AFPR: Breathless Performance
The kit does not include a fuel diaphragm, so I picked one up from south bay.
O2 sensor: Found an AC Delco one on Amazon.com for about $18, shipped. (Advance Auto parts said they couldn't get a Delco one on, but it was on their books for over $70. Scoggin Dickey wanted over $30 for the sensor.)
Old Mar 23, 2014 | 01:58 PM
wgripp's Avatar
I understand cleaning the EGR. What do you mean by cleaning the passage?
Thanks!
IROCDave
Mar 2, 2005 10:27 AM
89IROCZTPI
Oct 7, 2004 08:51 AM
JRoy91RS
Mar 19, 2002 12:52 AM
