best HP boosters for your buck?!!!!
Old Mar 30, 2014 | 04:30 PM
Hlvo13's Avatar
Car: 1989 pontiac firebird formula
Engine: 5.7 350 tpi
Transmission: 700r4 i think
hello all, I have an 89 formula and I'm looking for the best HP boosting aftermarket parts. I think I have to replace my fuel pump so I want to replace it with a high output pump, then I was hoping to put on a larger gauge throttle body and header back system. and a new intake. I already have a dual cat system but the guy I bought it from put the dual right back into the stock muffle so I'm also going to have full and true duals. I'm in college and she's my pride and joy so I'm just looking to see what y'all think of my plan. I want power of course and am looking to buy it as I can hopefully the exhaust first. any impute would be much appreciated. thanks all
Old Mar 31, 2014 | 07:47 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: best HP boosters for your buck?!!!!
I agree. A full exhaust set up from the headers all the way back to the tips will give you a noticeable difference. If the rest of your car is still stock, I wouldn't go for the larger throttle body as it wouldn't be needed at your power level.
Old Mar 31, 2014 | 07:58 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Finish filling out your profile so we can see specifics on your car.
I second the exhaust, and also wouldn't mess with the throttle body. Have you gutted your air box? Doing that plus a high flow filter (such as a K&N) would help the car breathe a little better.
Old Apr 1, 2014 | 11:36 AM
Hlvo13's Avatar
Engine: 5.7 350 tpi
I updated my info its all stock as far as I know and its been giving me a lot of trouble lately so im trying to first see what it will take to get it running right then map out a plan of parts to buy and install over the next year thanks for all yalls help
Old Apr 1, 2014 | 04:09 PM
vdoggie's Avatar
Car: 1991 Z28
Engine: 350 tpi
Transmission: auto/stock
Axle/Gears: stock
put the dual back into the stock muffler?? so it's duals to a single muffler and Y's out? If so, that makes no sense!!
headers if ya have the money and enjoy knuckle busting or spend a lot of monies for someone else to do it.. I just slapped on 3" with a dcat all the way back to an 80 series flowmastah and it sounds delicious and a little but viscous.. not so much that it annoys.. it's literally just right.. maybe headers but even this change made a very noticeable difference.. car is breathing very nice now.. should boost the gas mileage too!
otherwise just dump the money into the heads and super charge it if you are a person with plenty of cash.. have fun!
Old Apr 1, 2014 | 04:33 PM
Hlvo13's Avatar
Engine: 5.7 350 tpi
Yah i don't know why but right back into the stock muffler
Old Apr 1, 2014 | 05:10 PM
vdoggie's Avatar
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: stock
maybe it was too loud?
Old Apr 1, 2014 | 05:23 PM
Hlvo13's Avatar
Engine: 5.7 350 tpi
Maybe haha I know I'm going to undo it though lol
Old Apr 1, 2014 | 06:36 PM
HighTechRedneck's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: Stock 9bolt posi
75 shot of nitrous
Old Apr 1, 2014 | 07:25 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
So much [FAIL] in here...
smh
Old Apr 1, 2014 | 07:26 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
best seat of the pants mod to really change the feel, a higher stall TC and a drive way drop in shift kit.
couple hrs in drive way with a friend. a big smile every time ya flash the TV to stall speed n chirp gears......
only mod ive ever done that really changed things.
Old Apr 1, 2014 | 10:11 PM
vdoggie's Avatar
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: stock
smh
yeah... oooooooooh k Gandolf the gear head.. we all bow down to your wisdom of car mods..
Old Apr 2, 2014 | 01:17 AM
Thizizkai's Avatar
Car: Chevrolet Camaro Z28
For my Little bros 91 RS we went with K&N filter,full exhaust, and from there worked on suspension since the old 305 can only go so far on a minimal budget ($700 total budget)
Old Apr 2, 2014 | 05:28 AM
Hlvo13's Avatar
Engine: 5.7 350 tpi
hmm never thought of that, mine has the ws6 suspension I wonder if it would be worth switching out.
Old Apr 2, 2014 | 07:15 AM
Car: 1983 Z28
If you have the ws6 package your suspension is already pretty good, maybe swapping out any rubber bushings for urethane ones would be a good idea, but the sway bars are already a good size.
Old Apr 2, 2014 | 07:41 AM
Hlvo13's Avatar
Engine: 5.7 350 tpi
yah I know it could probably use new bushings, its been through a ruff few years
Old Apr 2, 2014 | 08:14 AM
Car: 88 IROC-Z
Did you even read half the junk listed.
Old Apr 2, 2014 | 08:40 AM
racerx520's Avatar
theres a lot of ways to boost hp...depends on how far you're willing to go. get air in and out faster will increase your HP basically. if you dont mind losing the LTR look, get an stealth ram, headers will increase the sound and hp of your car. better heads would be a great place to go too.
if you have budgeted just an exhaust job, and maybe a home made cool air intake with K&N filter, may i suggest too, a primo tune up. i never did that for my 87 (when it had the 305 TPI) and found that at nearly 165,xxx miles, it still had stock plugs, wires, cap and rotor. i definately gained some performance back from the motor after that
Old Apr 2, 2014 | 10:07 AM
vdoggie's Avatar
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: stock
did you bother reading the OP? It's stock except the exhaust which was re-modified back.. so yeah I did read all the "junk" and all of it was acceptable.. I didn't see anything constructive suggestions from you other than a holier than tho attitude towards all the "junk" people suggested..
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
BrianI
Oct 3, 2015 12:57 PM
thejimsterz28
Sep 30, 2015 08:52 PM
Damon
Sep 26, 2015 04:29 PM
