350 Vortec TPI - how to get 325-350 fuel efficient hp?
According to Scoggins Dickey, just adding Vortec heads and their Vortec TPI base to an L98 engine will result in 300 hp using the stock computer. I'd like to get 325-350 flywheel hp(and no more) with the best possible gas mileage and am wondering which of the cams below might do that using the original computer(my husband wants to use a mega-squirt computer but I don't see him having the time to set it up).
The motor is a flat tappet 79 L82 350, 10:1 compression Vortec/TPI with AS&M large tube runners. Scoggins Dickey says other modifications on their otherwise stock L98 such as camshafts, rocker arms and injectors produced as much as 375hp with the stock computer and throttle body. One of those included an LT4 Hotcam but seeing as Vortec heads max out flow at about .500 lift I think the extra lift of their 1.6 ratio hotcam was wasted and a milder cam would do just as well.
My goals for the motor might conflict a bit, I have a 5 speed and 3.70 rearend. The first gear is 3.37 ratio so I'm hoping to rev to 6000 rpm and not have the power drop off drastically. The fifth gear is .67 overdrive so I will be cruising at 2000 rpm at 62.5 mph. The cams I'm looking at (all designed for TPI) are:
Crane 2032: 214/220 duration, .452/.465 lift, 112 LSA, operating range 1800-5800 rpm
Comp cams 266HR-14: 210/220 duration, .500/.510 lift, 114 LSA, operating range 1400-5400 rpm
Comp cams XR269HR: 218/224 duration, .495/.503 lift, 112 LSA, operating range 1500-5500
Lunati 10120701 (flat tappet): 212/219 duration, .454/.468 lift, 112 LSA, operating range 1000-5500
Third Gen member Mike Crews
https://www.thirdgen.org/forums/afte...-tpi-dyno.html
used the Comp Cams XR269HR in his TPI/Vortec 383 with AS&M runners and produced 303 rear wheel hp at 5100 rpm and said he was really impressed with the gas mileage. He said the horsepower dropped off after that rpm but not much and it pulled all the way to 6000 rpm. Assuming a 20% drivetrain loss I work out that my 350 with a similar combo should produce 346 flywheel hp. Would I do almost as well with one of the other cams but get better mileage? What do you think?
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: 350 Vortec TPI - how to get 325-350 fuel efficient hp?
i like the crane 2032. i have it in my 305 with 1.6 ratio rockers, but i run stock style world product s/r torquer heads and edelbrock tpi base and accel runners.
not sure what the 350 will put out with that combo
why the need to rev to 6k? the tpi isn't made for that
I realize tpi isn't ideally suited to high rpm but I hope to coerce it to do so. The reason is my 3.70 rearend and 3.37 first gear which will result in 36 mph in first gear at 6000 rpm. I don't want to drop the clutch and have to shift out of first 1 second later at 25 mph. With those gears I really don't need the low speed torque TPI is known for although I do need it to be efficient for crusing at 2000 rpm.
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Getting the TPI to 6000 is going to be interesting. My Vortec headed HSR with LT4 hot cam slowly pulls to 6000 from 5500 with 3.90 gears.
Out of those cams I'd pick the comp, however.
Car: 89 Firebird
Engine: 355 TBI
I wouldnt recommend a lift of over.475 on stock vortec heads. I made around 320-340hp with stock vortec heads and a 218 218 hydraulic flat tappet cam with 465 lift and forged pistons. Headers and a carb.
Car: 1983 G20 Chevy
Transmission: 4L60
It was a 355, .030" over 350 with flattop pistons, 10.5:1 compression ratio, ported/milled 906 vortec heads with 2.05/1.60" valves, a reed custom grind
260/264* @ .008, 208/212 @ .050, .480/.507" lift w 1.6:1 rockers, 112* LSA, 108* ICL. running an edelbrock 3817 base that had been ported, and a set of AS&M long tube runners, doug Thorley tri-y headers and 2.5" dual exhaust. Run by a 7730 tuned by me on SAUJPv4
Fast355- to be fair to the rest of us- your setup is likely tuned to the Nth degree.
One thing that has never been explained to my satisfaction is the difference between single and dual pattern cam as it relates to a street set up, what is the deciding factor in the head vs exhaust. I`m using AFR vortecs, I`ve read that if the head has at least 85% I vs E your OK with single pattern that will give more torque, I`ve full single exhaust 3in with TES headers and Y-pipe.
Sounds interesting. I could modify the Vortec heads but it would be a bonus if I could use a cam that doesn't require that. How did you get that 320-340 hp estimate?
Car: 02 Hawk
Engine: 427
Axle/Gears: 3:42
If you don't modify heads looks like your choices are narrowed down to crane or lunati. They both look comparable to one another.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1983 G20 Chevy
Transmission: 4L60
Case in point.....My 2012 Titan was factory rated a 317 HP/385 ft/lbs of torque at the flywheel. I put a 4" CAI on it, ported the throttle body, removed the throttle body gasket screen, bypassed the coolant to the throttle body, removed the resonators and in their place put a 2.5" mandrel bent exhaust. I then tuned it for E85 and made 296 RWHP/388 RWTQ on a Mustang dyno that reads 10% lower than ANY Dynojet. Went 13.9/14.0s @ 96-98 mph, despite weighing 5,300+ lbs, having an open differential and heavy 305/50R20s on each corner. I was able to tweak the tune to get a fairly consistent 1.99-2.01s 60' in good weather. So a lot of it is working to get the best out of the combination you have.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1983 G20 Chevy
Transmission: 4L60
My most current 350 is running a marine intake from a 350 vortec powered boat. Aluminum edelbrock ETec heads and a custom grind comp cam. Makes 374 RWHP through a locked 4L80E in a 2nd gear pull and 9.5" GM corporate 14-bolt rear end. Was still making more than 350 RWHP @ 6,500. 325 ft/lbs @ 2,300 rpm.
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
