Timing cover with one piece oil pan gasket TPI
Old Apr 27, 2014 | 02:06 PM
FormulasOnly's Avatar
Car: 1989 Formula 350
Axle/Gears: 3:23
Anyone change a timing cover without dropping the pan or cutting the one piece gasket? Is there a easy trick or is this going to be trial and error?
Old Apr 27, 2014 | 04:43 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Timing cover with one piece oil pan gasket TPI
Originally Posted by FormulasOnly
Anyone change a timing cover without dropping the pan or Is there a easy trick ?
Anything is possible but short answer is NO if you plan on keeping oil in when finished
I suspect a hammer , chisel and real big tube of sealant will also do the job
Old Apr 27, 2014 | 08:21 PM
Axle/Gears: 3:23
Yep, I ended up cutting the U off and trimming the backside of the rubber gasket. Just did it like the Old School way with the 4 piece and a dab of silicone in the corners. So far so good
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
