Head Swap
Old May 4, 2014 | 03:35 PM
TipTricky's Avatar
Car: 1991 Chevy Camaro Z28
Engine: 5.7lt TPI L98
Axle/Gears: Drum Brakes, Not Sure Gears
Head Swap
Hey guys im back again curious of some opinions good or bad like them all. I have a set of 3927186 Camel Hump heads and they are just sitting in the garage. Would it be worth the time of installing them on my 91 l98 camaro? They are 2.02/1.60 64cc chamber heads. I will be doing some light porting on them at least a clean gasket match. Currently the stock heads on the l98 have bad valve seals so smokes on warm starts. Just change valve seals or head swap?
Old May 5, 2014 | 07:11 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Head Swap
The TPI heads have more bolt holes in the end of the head than the older stuff. You will not be able to bolt your alternator or a/c and power steering pump back on. Not to mention your base is cut for the four center bolts to sit at 72* rather than the traditional 90* of the older heads.
Long story short, the camel humps are a poor choice for your car. Valve seals will probably not change the main issue, aka worn guides.
xkingcodex
Feb 12, 2020 07:43 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
