Do I need a new TPS for speed density?
Old May 5, 2014 | 08:26 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am swapping my car over to speed density. I saw a listing for throttle position sensors being different for the 90-92 cars. Will my old tps from my MAF set up work with the speed density system, or do I have to change it for the other style?
Old May 5, 2014 | 08:46 AM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: Do I need a new TPS for speed density?
(subbed)
(thinking of converting to the later style myself)
Old May 5, 2014 | 09:20 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
If you keep old maf throttlebody and have map sensor tapped off plenum thru a vacuum line somewhere then no you do not need a new tps.
Old May 5, 2014 | 09:53 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I am keeping the old throttle body and did install a barb for the map sensor, so I should be good then. Thanks
earlpote
Sep 12, 2015 11:55 AM
adelane
Sep 9, 2015 08:51 PM
Eric-86sc
Sep 7, 2015 02:10 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
