t p i high idle
Subscribe
May 13, 2014 | 09:23 AM
hey guys,
it idles fine when i first start it,but after driving a few miles,the idle gets higher.
not real high,but the only thing i worry about is damage to the tranny,otherwise
i would be ok with it.any help appreciated.
Reply 0
May 13, 2014 | 09:40 AM
Re: t p i high idle
Most Tpi throttle body blades create a edge in the bores and can't close all the way. If it is idling high look and see if accelerator linkage on throttle body is touching the idle speed stop screw
Reply 0
May 13, 2014 | 11:17 AM
Re: t p i high idle
yes its touching the stop screw.if i turn it down,it will idle too slow after starting.
Reply 0
May 13, 2014 | 03:22 PM
Re: t p i high idle
you should look up how to set minimum idle air speed on this site, then verify that the TPS is at the right voltage...
Reply 0
May 14, 2014 | 08:20 AM
Re: t p i high idle
thanks.will do
Reply 0
Subscribe
