Anyone have problems with Accel base?
Old May 7, 2014 | 04:29 PM
racerx520's Avatar
today i finished putting the motor together and was putting coolant in before the first startup, coolant started pissing out the back of the motor, looks like from the intake manifold gasket. i have a used Accel manifold and aluminum summit heads. i bought a gasket recommended for the Accel base but i have heard there can be a large gap with the Accel base at the china wall. anyone know of any issues with this manifold? i paid a good amount for it and i dont want to find out that i got screwed cuz its junk.
Old May 7, 2014 | 07:37 PM
racerx520's Avatar
Re: Anyone have problems with Accel base?
i used the felpro 1205 for the intake manifold gasket, but i did not use the china wall gasket for that, i had one on a while prior from a felpro gasket set for stock, i dont know if that could be part of the issue
Old May 7, 2014 | 11:32 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
just curious if you installed a 1/8 npt plug on the corvette coolant bleed hole in the rear of the intake on the coolant crossover passage .
Old May 8, 2014 | 06:46 PM
racerx520's Avatar
i dont think i even looked for such a thing. i dont remember even paying attention to the rear of the intake manifold. i bought it used and was told it was in a running third gen so i figured i'd just throw it on and run it. hopefully tearing it down tomorrow or monday so i'll definitely look
Old May 11, 2014 | 03:32 AM
Engine: Lb9
Transmission: M20
It is between the corvette egr feed and distributer hold down.
Old May 13, 2014 | 09:27 AM
racerx520's Avatar
ah, yes i do have that screw in. the water is coming from the other side of the intake though. the other day i had taken apart the intake again, i found the gasket the guy recommended (felpro 1205) fit worse than a stock intake manifold gasket so i ditched it, going with a stock one, siliconed up around the water jackets and also found that where one of the runner bolts goes, apparently is tapped into the water jacket of the intake manifold, cuz water leaks from there too, so a little teflon tape on that bolt should solve that issue too....today is reassembly have to see how it goes
Old May 13, 2014 | 10:06 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Subscribed, could you post pics of the areas you mentioned? I'm getting ready to do this same swap with a new edelbrock piece and would like to see where the potential problem lies.
Old May 14, 2014 | 11:20 AM
racerx520's Avatar
well the area i had the issue with was the back drivers side area. the bottom long screw in the rear long tube header was the one that seems to be into the water jacket. unfortunately i did not take any pictures and the runners and plenum are all reinstalled. i'll see if i have any older pictures when i was assembling to take a look at.
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
hydrolic144
Aug 29, 2015 04:14 PM
Fronzizzle
Aug 9, 2015 01:15 PM
