Threaded holes near coolant temp sensor on intake manifold
Old May 22, 2014 | 04:37 PM
jimmydz28's Avatar
Car: 1989 Camaro IROC-Z
These two holes are just left open, right by the CTS on the intake manifold.... i was spraying for vac leaks and sure enough my idle kicked up. Every pic i look at on peoples cars these holes are left un-capped or plugged with a bolt.. however in my case im getting a small vac leak? anybody elses have theirs covered?
Old May 22, 2014 | 07:15 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Threaded holes near coolant temp sensor on intake manifold
Just blind holes in mine (nothing in them). But I'm running an Edelbrock lower manifold.
Are you testing with the bellows removed from the throttle body? The engine is most likely sucking in whatever you're spraying through the throttle body causing the increase in RPM.
Old May 24, 2014 | 10:33 AM
jimmydz28's Avatar
i actually threw bolts in them, now the car idles PEREFECTLY... so there you go lol
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
