funny stumble,code 33
Old May 26, 2014 | 10:09 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
so in driving the car, i am, on occasion, getting a funny stumble ,like i lose 30 or so hp and the CEL will come on. but it goes off almost immeadiately and the stumble will go away .for awhile. then it repeats.now i know that code 33 is MAF signal voltage is high .what im trying to find out is...why. the FSM says that the MAF gets its power from the fuel pump relay. could it be going bad? causing the MAF to get too much power? any guidance on this ???
Old May 26, 2014 | 03:26 PM
Car: 86 IROC
Engine: 5.0 TPI
Re: funny stumble,code 33
so I unplugged the ECM fuse by the battery,waited 30 minutes or so.and when I reconnected it and started the car it stumbled a bit then smoothed out nicely.no CEL and everything SEEMS ok??!? drove it 30 or so miles and its smooth as butter.i guess that is what is meant by "intermittant"?
Old May 26, 2014 | 08:34 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
could it be going bad? causing the MAF to get too much power? ?
The code is for the ECM seeing a air flow rate indicated greater than what it expects at a certain time / conditions;
not too high a voltage from the battery
http://www.chevythunder.com/maf_code_33.htm
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
RedLeader289
May 28, 2019 01:47 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
