Cylinder head questions?
Old May 28, 2014 | 04:51 PM
MattGibson1's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.0
Axle/Gears: stock
Hey guys. I was looking for some budget heads for a '89 350tpi. I was mainly just looking for some heads I could get for $500 or less and clean up myself. There are some double hump heads for sale on my local Craigslist for $250 and I was wondering if they would be a big improvement over stock? I was planning on putting some aluminum roller rockers on them and maybe doing some light porting work myself. Also, can you put 55-87 heads on a later motor. Sorry, I couldn't find much information. Thanks!
Old May 28, 2014 | 05:48 PM
Chad85T/A's Avatar
Car: 85 T/A
Re: Cylinder head questions?
Your money would probably be better spent on something other than heads. Whatever you do I wouldn't put those old style heads on there.
Old May 28, 2014 | 05:50 PM
Engine: 5.0
Axle/Gears: stock
Really? I've only heard good things about them.
Old May 28, 2014 | 06:17 PM
Chad85T/A's Avatar
Car: 85 T/A
Vortecs are WAY better. Those are the old style bolt pattern and perimeter bolt valve cover. Your intake will have to be slotted to bolt in the middle. You current valve covers won't work. If your wanting to spend some money on performance, try some tuning. You'll just be disappointed if you swap for those heads. If you want to stick with TPI, put some hi flow runners on it, or switch to the HSR. At the very least go vortec if you are dead set on swapping heads.
Old May 28, 2014 | 06:18 PM
Engine: 5.0
Axle/Gears: stock
Would vortecs bolt right on? And do you mean the vortecs off of the mid 90's tbi motors?
Old May 28, 2014 | 06:21 PM
Chad85T/A's Avatar
Car: 85 T/A
I mean vortecs as in 96-99 truck engines. They'll bolt straight to the block, but they do require a vortec specific lower intake manifold.
fasteddi
Sep 2, 2015 10:29 AM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
