vacume line
Old May 29, 2014 | 11:32 AM
zz top 34's Avatar
Car: 34 ford
Engine: 1986 camero tuned port
Axle/Gears: ?
vacume line
hey guys,
just noticed a cut off rubber vacume line on the rear drivers side going to the intake.car is running fine except for slightly higher idle after it warms up.if i block the line with the car running,it imediatly stalls.if i block it and then start ,it runs ok ,but with massive air sucking into intake.think it might be for brake booster,but why am i just noticing it now,and how do i correct it? any ideas appreciated.[86,305]
Old May 29, 2014 | 12:23 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: vacume line
Try here
https://www.thirdgen.org/forums/tech...+line+diagrams
Old May 29, 2014 | 12:31 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: vacume line
Also, if you have cruise control, there is a vacuum line that runs around the back of the engine to the cruise that "Tees" to the vacuum ball located in the front drivers fender. AND A BEAR TO SEE!
Old May 29, 2014 | 12:34 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: vacume line
Originally Posted by zz top 34
hey guys,
Brake booster to intake is a rather large hose!
Old May 29, 2014 | 01:22 PM
zz top 34's Avatar
Car: 34 ford
Axle/Gears: ?
Re: vacume line
hello,
its an 86 305 with t p i 7004r tranny.appreciate the help.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
