still cant get 85 z28 tpi to start
Old Jun 7, 2014 | 12:01 AM
Crudsturbo's Avatar
Ok ive posted in the past with no luck. 85 z28 tpi definitely has spark, new cap, new rotor,new plugs, new wires, new coil, and pickup coil tests fine. Have 40psi for fuel pressure even when cranking. The car will crank but not start. Forst off replaced ecm but was starting prior and after. New ecm gave me code 34 which was maf. Found the ceramic wire broken inside. Have maf off the car now and misplaced it doh! But am told by many it should still start. I just cant see it doing so without it. Even spraying starting ffuid it doesn't even try to start. And yes spark good, gas good, compression good. What could it be?
Old Jun 7, 2014 | 12:58 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: still cant get 85 z28 tpi to start
And yes spark good,
If if won't kick with fluid ; spark ( or timing ) is still a suspect
Are the plugs wet or dry when it won't fire ?
Old Jun 9, 2014 | 12:01 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I agree, double check your timing
Old Jun 12, 2014 | 04:42 PM
85Special's Avatar
Car: Silver 1985 IROC-Z
Transmission: 700-R4
IAC and TPS as well. Be sure there set properly. I miss adjusted mine and I could crank her over all day long to no avail. Reset IAC and TPS... instant startup. I've had my timing set anywhere from 6-12 degrees, it didn't like being over advanced but it always started. Make sure your disconnecting the wire when setting timing. And mine is an 85, it will start with the MAF off.
Old Jun 12, 2014 | 05:15 PM
MecGen's Avatar
Are your injectors pulsing ? check them with a noid light.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
