TPI plenum question
Old Jun 10, 2014 | 08:04 AM
johndinu's Avatar
Car: '89 GTA 350 hardtop
TPI plenum question
Hi,
Took off my throttle body (car is 89 gta 350) and noticed the plenum does not have that triangular shaped opening in between and under the two round openings... Was wondering what's up with that?
Are like two kinds of tpi plenums out there, with and without that thing?
Obviously the gasket has an opening there and the corresponding cavity in the throttle body is not sealed.
so air finds its way into the plenum... dunno if that's for air or exhaust gas recirculation...
thanks
Old Jun 10, 2014 | 09:25 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: TPI plenum question
85 to '88 and '89 to '92...two different ones, but I forget which is which
Old Jun 10, 2014 | 10:59 AM
johndinu's Avatar
ok thanks for the reply.
now are there specific tb to plenum gaskets to account for the differences?
in my case the IAC air goes thru the gap in between the tb and plenum not sealed off by the gasket... I guess that's normal, otherwise the engine would not idle
thanks
Old Jun 10, 2014 | 11:20 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hopefully someone will chime in...it's been ages since I looked at the two..but I do believe the IAC passages are different.
I have a few TB's and plenums in the shop and will look at them later today and see what I have.
Old Jun 10, 2014 | 11:28 AM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
There are 3 different plenums. 85-88, 89, 90-92. The 89 is a one year only.
Old Jun 10, 2014 | 11:47 AM
85Special's Avatar
Car: Silver 1985 IROC-Z
Transmission: 700-R4
85-88 has the dreaded 9th injector port.... Dun Dun Dunnn. I can't wait to plug mine off. 89 was no 9th. 90-92 was MAP instead of MAF??? Think that's right.
Old Jun 10, 2014 | 12:01 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think the only difference in 89 vs the SD plenums is a hole/fitting for the MAP sensor on the SD's.
Pretty sure the rest of the casting is the same, or is some else different as well?
Old Jun 10, 2014 | 03:30 PM
johndinu's Avatar
ok, just checked, the tb gaskets are indeed different. for the 89+ (without iac passage in the plenum) the tb gasket it's opened in the sense that the two tb openings communicate. the earler style, the tb openigs do not communicate.
thanks everyone!
MantyZ28
16
Dec 21, 2015 11:02 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
