1991 Z-28 dies at stops when at operating temp.
Car: 1991 B4C blue
Engine: 5.7 TPI
Axle/Gears: 3:23
I have a 1991 B4C that when at operating temp dies. It will also die when warm and put into gear at a stop. When it dies it is like the ignition shuts off. It just quits. When the car is below 160 degrees it operates normally. Any suggestion would be great. It is a 5.7tpi auto car. Thanks. Nate
Car: check
Engine: check
Transmission: check
Re: 1991 Z-28 dies at stops when at operating temp.
If the OEM Multec injectors are still in the engine replace them.
If not, then the next time it won't start, check the fuel pressure, check for spark. If have spark and it won't start shoot a small squirt of starter fluid into the TB and see if it runs for a moment. If so you have a fuel issue.
RBob.
RBob.
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Check out the pickup coil as well.
They get hot, no workie, cool off and you might get home.
All other suggestions were valid as well.
Car: 1991 B4C blue
Engine: 5.7 TPI
Axle/Gears: 3:23
Well it turned out to be the the magnets in the distributor were corroded and cracked. Just giving heads up incase anybody else runs into this. Removed and replaced distributor and coil. Runs great now. Thanks for all your help!!! Nate
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Had a similar problem with a 73 Plymouth Satelite. Shut it off warm would not restart in till motor was cold. Broken wire in magentic pick up in Dizzy.
