Throttle position sensor upgrade??
Old Jul 2, 2014 | 07:06 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
I saw on ebay a wring adapter that converts the TPI TPS connector to an LT1 style TPS. I was curious if there is an advantage to doing this?
Old Jul 4, 2014 | 02:39 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Throttle position sensor upgrade??
Not that I can think of. Unless the LT1 unit is cheaper.... Or, if you wanted to upgrade to an OBDII system........
Old Jul 10, 2014 | 03:11 PM
92GTA's Avatar
Only "upgrades" I've ever found on electronics is buying all NippiDenso and throwing the shitty Bosch stuff in the trash fast as I can
Just call as many different suppliers as possible and ONLY ever use AC Delco or Denso, F Bosch.......and yes some AC Delco stuff is OEM'd by Bosch so you gotta be careful...
K, rant mode off haha
9192camaro
16
Feb 3, 2019 12:21 AM
someone972
Aug 30, 2015 12:52 AM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
