skip new street fire new wires n plugs
Old Jul 15, 2014 | 11:10 AM
jman1234's Avatar
Car: 1990 firebird formula one
Engine: 305 tpi
all new plugs wires street fire ignition box and coil getting a skip like its missing spark arc or something new injectors fuel pump fuel psi 43.5 timing at 6 wtf pissing me off any ideas ne one plus new tps o2 knock map all sensors new volt at .450 on tps
Old Jul 15, 2014 | 12:51 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: skip new street fire new wires n plugs
First, you didn't mention a cap and rotor? Second, you should have the tps voltage up at .54 or even a little higher.
Old Jul 15, 2014 | 02:52 PM
jman1234's Avatar
Engine: 305 tpi
it is at .540 my bad will try turn it up a bit and am planing on new dis and cap when i get home from saint louis whats the hi side you can set tps bffore it throws a code at ya
Old Jul 15, 2014 | 04:24 PM
red rock's Avatar
Car: 1987 iroc
I set mine at .60-.65 It gives a little better throttle response and doesn't throw any codes. As far as having a miss, replace the cap and rotor and check over all your wiring on the ignition box. I'm curious as to how the engine ran before you started throwing parts at it?
Old Jul 15, 2014 | 06:58 PM
jman1234's Avatar
Engine: 305 tpi
didnt run when i got it po said he put new distributer on and forgot to boult it down jumped time so i set distributer then it would start and stall after one or two seconds found out it was a bad injector on bouth sides of rail witch shut down the injector pulse now it runs grate no smoke changed plugs no sign of oil burning just when ya wana stomp it it skips like spark is arking maby shitty 7mm plug wires cant handle extra volts think there super max 13 7mm wires there new thought was changing all intake gaskets plus injectors might as well due plugs wires all sensors hole tune up fuel pump its my day to day car so dont need break down o got new adjustable fp reg to for hell of it
Old Jul 15, 2014 | 08:36 PM
red rock's Avatar
Car: 1987 iroc
If you are not running any aftermarket chip in the ECM, you could bump the timing up to 8 and try it. Are you disconnecting the EST wire on the firewall when you adjust the timing?
Old Jul 15, 2014 | 08:38 PM
jman1234's Avatar
Engine: 305 tpi
yes i un plug it and it runs more slugish at 8 better at 6 dont know y but seams run bogy at 8 deg
Old Jul 15, 2014 | 08:43 PM
red rock's Avatar
Car: 1987 iroc
Then i would keep it at 6. I guess you won't know till ya get home and check the cap and rotor and go from there.
Old Jul 15, 2014 | 08:47 PM
jman1234's Avatar
Engine: 305 tpi
rember under cap had some rust think it got wet and sat out
Old Jul 15, 2014 | 09:07 PM
red rock's Avatar
Car: 1987 iroc
I'm sure it has a bunch of carbon build up on the brass also.
Old Jul 15, 2014 | 09:10 PM
jman1234's Avatar
Engine: 305 tpi
right thanks for hlp just want a fun car to play with thinking get tune right and adding full exhaust and some nos in a bit
Old Jul 17, 2014 | 08:31 PM
jman1234's Avatar
Engine: 305 tpi
man the distributor was all slopy and binding little bit new distributor in now no skip any more now i play with timing a lil bit see how it goes but much bettet now 6 deg time gona try 8 tomorow and up volts on tps
Old Jul 17, 2014 | 10:32 PM
red rock's Avatar
Car: 1987 iroc
Good job! I guess that would do it.
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
djmarch
Aug 19, 2015 12:07 PM
Jk_Under
Aug 17, 2015 03:08 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
