Help Needed!! - TPS Voltage wont reach max at WOT
Old Jul 25, 2014 | 10:04 PM
mdtoren's Avatar
Car: 1986 Iroc Z28
Hey gents and ladies,
Ive got a code 22, TPS issue. Volted it out and found initially voltage at idle of .36 and WOT of 3.5...So naturally adjusted idle voltage up to .54 and checked WOT..still 3.5.
I have been having issues with stalling at lower speed, a cam-like rough idle (would love to keep that haha), running rich, and stumbling and stuttering at higher RPMS. Is a TPS replacement needed? Any other ideas? just put in a new coolant temp, iac, and o2.
As always, thanks in advance for any help.
Old Jul 26, 2014 | 09:46 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Help Needed!! - TPS Voltage wont reach max at WOT
you have probably got a bad TPS. if it wont go all the way up, its suspect.check it with a vom. if you do not have a linear increase in voltage signal .theres your problem.and the stock ECM is looking for .5v at idle and 5v at WOT.
Old Jul 26, 2014 | 07:22 PM
mdtoren's Avatar
Car: 1986 Iroc Z28
I will try that out tomorrow, thanks for the reply!!
Old Jul 26, 2014 | 09:58 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Just something quick to check while your in there, the ECM supplies 5V to the sensor and the TPS sensor is just a voltage divider that feed some % of that voltage back to the ECM. As stated the TPS sensor's resistance may not vary as it should, but it will never work right if the ECM is not supplying the 5V reference or if it does not have a good ground. Check to make sure you have 5V coming from the ECM and a good ground.
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
