help quick question thats driving me nuts look at pic and tell me what you think
Old Aug 1, 2014 | 04:14 PM
snipzors's Avatar
Car: 87 iroc z
Engine: 5.0 TPI
Transmission: t5
Axle/Gears: stock
ok so i was in the middle of installing a new center bolt to perimeter bolt adapter to fit some tall valve covers, when i accidentally dropped a cylindrical washer that was part of the adapter down the hole that is in the head. im not exactly sure where it goes and whether i now have to pull the whole valve train to get it back out please any help
will attach photos
Attached Thumbnails help quick question thats driving me nuts look at pic and tell me what you think-imag0347.jpg
Old Aug 1, 2014 | 05:23 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: help quick question thats driving me nuts look at pic and tell me what you think
Maybe you'll get lucky and you can snag it with a long magnet. It's in your block's valley. If you can't get it with a magnet you'll need to pull the intake manifold and it should be right there. If it's at a far end of the block it could make it's way to your oil pan.
Old Aug 1, 2014 | 05:38 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Try a shop vac with a small rubber hose taped to the end
Old Aug 1, 2014 | 09:46 PM
snipzors's Avatar
Car: 87 iroc z
Engine: 5.0 TPI
Transmission: t5
Axle/Gears: stock
good call Sir!!!
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
mustangman65_79
Aug 8, 2015 12:07 PM
