Tpi wont start fuel in vacuum lines??
Old Aug 6, 2014 | 10:51 AM
79monte's Avatar
Hey guys I always appreciate your help. I'm wrapping up my intake swap and I can't get it to start. I have spark and fuel in the rail but I also have fuel in vacuum lines. Is that indicative of a fuel pressure regulator? Would that make it not start? I'll post some fuel pressure numbers later tonight and test the injectors with noid light. Thanks again for any advice guys.
Old Aug 6, 2014 | 11:06 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Tpi wont start fuel in vacuum lines??
Torn diaphragm in FPR will send fuel through the vacuum lines
Old Aug 6, 2014 | 11:27 AM
79monte's Avatar
You think that would cause no start condition?
Old Aug 6, 2014 | 11:31 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I would have to say yes. What is your FP on the rail? Do you have fuel coming out of the FPR when you turn the key on and the FP primes?
Old Aug 6, 2014 | 11:38 AM
79monte's Avatar
I will check fuel pressure when I get home and let you know. I didn't see fuel coming out of the fpr even with the line off
Old Aug 6, 2014 | 11:56 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
If you have a hand-held vac pump/gauge throw it on the FPR and see if it holds. If not, the diaphragm is shot.
Old Aug 6, 2014 | 02:32 PM
79monte's Avatar
Old Aug 12, 2014 | 07:40 PM
79monte's Avatar
Fuel pressure primes to 45 psi. I checked and I don't have injector pulse. I bought my distributor on eBay used so I'm going to start in there?
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
apie2546
Aug 10, 2015 05:43 PM
