Engine surges a bit until warmed up
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Hey guys, did a search on this but didn't find anything helpful. The engine surges a bit on start up and after it warms up the surging stops, looking for some input on what to do to correct this.
Thanks!
Thanks!
Car: 85 iroc z, 03 ram 1500
Engine: 305 tpi, 287
Transmission: WC T5, NV3500
Axle/Gears: 3.42, 3.55s
Re: Engine surges a bit until warmed up
the egr (exhaust gas recirculation) valve is most likely stuck open u and try taking it off and working the diaphragm with wd-40 or something similar. or a new egr would also work.
