EVAP canister with Mono blade throttle body
Old Aug 19, 2014 | 07:16 PM
355sbcTPI's Avatar
Car: 1983 Camaro Z28
Engine: 355 Tuned Port with Vortec Heads
Transmission: T56 six speed
Axle/Gears: 373 10-bolt
Hello Thirdgen's
I wanted to say thank you for all the help on this forum. I've been on here for years now and I wouldn't have been able to mod my car without the help from you guy's.
After 13+ years, my car is almost finished now. At the moment I'm hooking up vacuum lines and I'm unsure of what I should do with the EVAP canister line. I have a 1300cfm mono blade tb from TPIS...I think it's 1300 anyway. I bought it years ago off of Ebay. I decided long ago that I was going to keep the canister because I didn't want the gas smell if I git rid of it and I didn't want an empty spot if it was gone...that's just me, it's what I decided.
This throttle body has no hookup for the evap canister. Does anybody know what I should do with the line that goes from the canister to the tb? Can I plumb it in another way?...I've been searching but haven't found an answer yet!
Thanks for the help.
Just want to give John in RI a shout out! He's helped me a lot.
Old Aug 19, 2014 | 08:56 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: EVAP canister with Mono blade throttle body
Pic of said throttle body?
Old Aug 20, 2014 | 09:00 AM
355sbcTPI's Avatar
Here it is. My engine bay is still work in progress but almost complete!
Attached Thumbnails EVAP canister with Mono blade throttle body-img_0735.jpg   EVAP canister with Mono blade throttle body-img_0734.jpg   EVAP canister with Mono blade throttle body-img_0733.jpg
Old Aug 20, 2014 | 03:18 PM
355sbcTPI's Avatar
Here is a couple more side pic's.
Attached Thumbnails EVAP canister with Mono blade throttle body-065.jpg   EVAP canister with Mono blade throttle body-img_0736.jpg   EVAP canister with Mono blade throttle body-img_0737.jpg
Old Aug 20, 2014 | 09:28 PM
TTOP350's Avatar
The only pic of it is to small to see anything. I have put a small filter on the evap hose and put it in the airbox housing.
Old Aug 20, 2014 | 09:32 PM
355sbcTPI's Avatar
I'm at work right now, I'll post larger pic's later
Old Aug 21, 2014 | 02:31 PM
355sbcTPI's Avatar
bigger pic's
Attached Thumbnails EVAP canister with Mono blade throttle body-img_0736.jpg   EVAP canister with Mono blade throttle body-img_0737.jpg
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
gixxer92
Sep 1, 2015 04:32 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
