It just doesn't run right
Old Aug 25, 2014 | 01:15 PM
busterbrown's Avatar
Car: 1992 formula firebird
Engine: 355 TPI
Transmission: currently a T-5, eventually a T-56
Axle/Gears: 3:42
I have a 92 with a transplanted 350 TPI. To the best of my knowledge everything is wired correctly. My issue is that the variable timing doesn't work. I have set the base timing and reconnected the Tan and black wire back together and the timing stays where it was set. Example: TPiS recommended a base timing of 6 deg with the chip that they programmed, I set the base timing and reconnect the wires as instructed and the timing remains at 6 deg. What am I missing? Is this an ECM issue? Any help would be appreciated.
Old Aug 25, 2014 | 09:06 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: It just doesn't run right
Does the check engine light come on when you disconnect the EST wire? And when you connect it, shut the engine off and restart it does the light go away?
Old Aug 25, 2014 | 09:56 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Try putting the original PROM back in the ECM and see what happens to the timing.
Old Aug 27, 2014 | 08:35 AM
Engine: 355 TPI
Axle/Gears: 3:42
When i built the dash I didn't put an engine light back in it. As far as the original prom, it was reprogrammed by TPiS and I do not have a donor to use.
Old Aug 28, 2014 | 11:23 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
no CEL!? now that's living on the edge, right there. fix that. find a correct MEMCAL for your car.
Old Aug 28, 2014 | 12:05 PM
Engine: 355 TPI
Axle/Gears: 3:42
MEMCAL???? I have no idea what that is. As far a the CEL I am in the process of squaring that away.
Old Aug 28, 2014 | 12:51 PM
Car: 86 IROC
Engine: 5.0 TPI
its that blue thing behind the access cover on your ECM. it is what tells your car how to act,so to speak. some call them "chip sets" the correct one will go a long way twards fixing your issues.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
bamaboy0323
Aug 15, 2015 07:20 AM
mizz0313
Aug 12, 2015 06:45 AM
Sherpajames
Aug 7, 2015 06:56 PM
