89 350 TPI hard cold start
Old Aug 26, 2014 | 11:42 PM
RTGTA's Avatar
Car: 2009 Silverado 1500
Engine: 5.3 Vortec
Hello everyone. Just started having this issue the past weekend. When the car is cold (after sitting overnight) and I crank it, it has an extended crank and then fires and dies. I can crank again and it will crank and fire normally. I recently replaced the oil pressure switch due to erratic gauge and rough idle. I am thinking that I may have a bad fuel pump relay and the pump is not going until I have oil pressure. Any ideas/suggestions? Thanks in advance.
Old Aug 28, 2014 | 07:28 PM
RTGTA's Avatar
Engine: 5.3 Vortec
Re: 89 350 TPI hard cold start
So no ideas? lol Anyone? I'm so alone
Old Sep 1, 2014 | 05:33 PM
RTGTA's Avatar
Engine: 5.3 Vortec
UPDATE: I checked the relay today and it tested ok. Re-connected and tested and now the pump will prime when the key is turned on. Suspect it was just a poor connection. All good now!
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
