stall/idle surge
Old Aug 28, 2014 | 10:16 AM
Al90IROC6's Avatar
Car: 1990 Chevy Camaro IROC-Z
Transmission: TH700r4
Axle/Gears: 3:73:1 posi
stall/idle surge
ok so I have been searching through all the threads and am at a loss. My '90 Iroc with a 305 TPI likes to stumble and stall sometimes when hot. It happens at low speeds in traffic or in a parking lot. Ill be at around 1000 to 1500 rpms and let off the gas and it boggs down to 200 or less rpms and sometime stalls out. I have removed and cleaned the IAC, checked the TPS, and ohmed out the injectors hot and cold. TPS was at .59V closed and 4.3V wot. Injectors 16.2-16.6 cold and 17.2-17.5 ohms hot. Timing has been set to 6 degrees. Off idle and driving it drives great, no issues. Only when at low speeds does it start to act up. Any insight would be greatly appreciated. Oh and no codes when checked.
Old Aug 28, 2014 | 10:55 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: stall/idle surge
a really complete tune up. could be in order. how old is your ICM? and im finding that although the TPS does have a little wiggle room, they seem to work best set at .5v at idle. and you should be seeing 5v at WOT. any deviation from these specs will cause what you describe.
Old Aug 28, 2014 | 11:17 AM
Al90IROC6's Avatar
ICM is about 4-5 years old, same with distributor. Ill try playing with the TPS and see what happens.
Old Aug 28, 2014 | 12:39 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
I've got similar symptoms.. and plan on replacing my distributor with an MSD unit. The contacts on the inside the cap and rotor on mine look good. I've already replaced all the simple stuff with AC Delco, i.e. TPS, IAC, plugs, etc....
Old Aug 28, 2014 | 12:56 PM
Al90IROC6's Avatar
well if it fixes it Im going to feel dumb. I took the cap off to check ac voltage out of the pick up coil and found green corrosion on all the terminals inside the cap and the rotor as well. so I have one coming for this afternoon. we will see. Thanks for the replies!
Old Aug 28, 2014 | 01:13 PM
Car: 86 IROC
Engine: 5.0 TPI
believe me, its better to FEEL dumb, than to BE dumb. and green corrosion is a big no no as far as ignition components go. it may well be all you have to do to get it right.good luck and post what your results are.
Old Aug 28, 2014 | 03:18 PM
Al90IROC6's Avatar
Yea right as I took it off and saw it I kicked myself for no checking that first. Forgetting the basics.... Ill post again when I have it situated.
Thanks again!
Old Aug 29, 2014 | 07:06 AM
Al90IROC6's Avatar
well put the new cap and rotor on and it definitely runs better, but still surges down and stalls at low idle
Old Aug 29, 2014 | 08:48 AM
Al90IROC6's Avatar
feels like a fuel issue. going to check fuel pressure and see if I have a leaky or clogged injector
Old Aug 29, 2014 | 12:54 PM
Car: 86 IROC
Engine: 5.0 TPI
a clogged injector would give a dead cylinder. and a leaky one would make it have a hi idle speed and smell rich. re set your TPS and see how it does.
Old Aug 29, 2014 | 12:59 PM
Al90IROC6's Avatar
I will try the TPS. I checked fuel pressure and it is at 36psi at idle and 46psi with the vacuum line off the regulator. when I shut it off the car pressure drops 20 psi in 30 seconds. regulator and pump are about 3.5 yrs old.
Old Aug 29, 2014 | 01:05 PM
Car: 86 IROC
Engine: 5.0 TPI
in the tank, there this thing ,a "pulsator". it goes between the FP and the pipe on the sending unit. with a pressure drop like that.sometimes you will find that rubber piece has gone bad. of course you should see if your regulator is leaking as well. that could also be an issue .
Old Aug 29, 2014 | 01:35 PM
Al90IROC6's Avatar
thanks. Just used am EFI probe tool while car was running and when it started to stumble found that #5 injector would cut out randomly. Gonna need to save some cash and get some bosch 3's!
Old Aug 29, 2014 | 01:38 PM
Car: 86 IROC
Engine: 5.0 TPI
well, there you have it. another happy customer!!!!
Old Aug 29, 2014 | 02:14 PM
Al90IROC6's Avatar
yup thanks for your help
92camaro350cci
Oct 14, 2015 09:29 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
bamaboy0323
Sep 3, 2015 06:07 AM
jbd1969
Aug 17, 2015 07:06 PM
