Anyone have a factory TPI intake on the bench, or one with the injectors out?
Old Aug 28, 2014 | 03:44 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I need the depth of the injector holes.
I had contacted South Bay because I'm going to put an Accel base on, and they say I don't need the adapters used for the Bosch injectors on the factory intake...I won't have mine apart until this weekend to compare with my Accel base, but if they are the same depth, I can call South Bay and discuss on the phone.
Thanks if you can help!
Old Aug 28, 2014 | 05:16 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: Anyone have a factory TPI intake on the bench, or one with the injectors out?
Have an accel on the bench if I can get over the the shop where I do some work tonight Ill take a peek.
Yrs ago put some Boschs on type 2 and from what I remember they were fine, I just didnt use the clips. Its been yrs though
Old Aug 28, 2014 | 05:33 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I have the Accel which I can measure quickly enough, but I need to see what the factory base manifold measures...as mine (factory) is not apart right now.
I think SB is selling the refurb'ed Bosch 3's which are shorter than the stock injectors, hence why they have made up adapters/spacers for them...but the price is just right at 165 for a rebuilt set of 8 and a warranty.
Dang I never should have sold all my old TPI spares
Thanks though!!
Old Aug 28, 2014 | 06:27 PM
IROC-Turbo's Avatar
I have a couple stock ones sitting on the bench.305 ones though if that matters.
I have no hightech measureing equipment but i'll do what I can this evening.
Old Aug 28, 2014 | 08:04 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Appreciate it...just a wire to the bottom...along the side, then a tape measure to how much wire went in, should suffice.
Thanks again!
Old Aug 28, 2014 | 08:39 PM
IROC-Turbo's Avatar
Couldn't locate my digi-calipers so I did the tiewire tape measure trick.Did it 3 times and each time came out to 11/16",maybe a supersmall fraction of a mm under that.
That measurement was from the top flat edge of the intake at the bosses down to the stop ledge in the bore.
Is that what you needed?
Oh and the rubber washer ring was still showing where where it sat.It was about midway between taper and stop ledge,but slightly closer to the taper.
Old Aug 28, 2014 | 08:48 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Awesome my man...just the info I needed...next time through Ca., I owe ya a beer!
Old Aug 29, 2014 | 12:24 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Dang, South Bay is closed for a few days...but checked my Accel base quickly, and got 5/8th...close enough for me to assume factory specs...grrr, dang thing gonna sit now, was hopping SB would be open tomorrow~
Thanks again Turbo!
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
masonta
Aug 31, 2015 10:14 PM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
