TPI injector upgrade
Old Sep 8, 2014 | 09:16 PM
83firebirdguy's Avatar
Car: '83 trans am T-top. With UMI stuff
Engine: '69 L48 350 tpi w/vette tune
Transmission: b&w t5 with torque arm relocate
Axle/Gears: 3.23 single tire fire
hello everyone,
I decided after some injector issues to look at other ideas for injectors since the ones our tpi's come with are junk! I seen the bosch 3s that southbay offers and was thinking what other injectors are similar that don't need adapters..
so I discovered that gm L36 3800 {non supercharged} also runs 22# injectors and up to around 2002-03 had the same plug as ours.
the gm 3.4l engines use the 19lb injectors for the 305's up to around the same years the plugs are the same.
I have found that after 2003 the injectors changed to a new style on both engines and have a new plug.
I decided to take a chance and got 8 number matching injectors of the new style from a local yard and got the plugs with them as well, it has been a week now and the car has been running amazing. it was the best 80$ I spent in a while that made such a big change. almost forgot all I had to change other than the bottom oring was 4 plastic nubs on the new injectors had to be nipped off with some cutters so they would fit in the rail at the top
I figured since I have never seen anything I would just put this out there for you guys
I tried to attach a pic so hope it worked
Old Sep 8, 2014 | 09:28 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: TPI injector upgrade
Good info in a pinch, but I like SB's deal, along with the 3 year warranty on rebuilt and flow matched pieces.
But like I said, that's solid info if you are down, and have some time to find them.
Old Sep 8, 2014 | 10:12 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Great info! I'll be swapping from carb to TPI soon and there are lots of those engines in the yards around me. Any idea what the # rating is on the injectors in the supercharged version of the 3800? Just in case I need a cheap upgrade?
Old Sep 8, 2014 | 10:28 PM
those are 36#
Old Sep 9, 2014 | 07:45 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Originally Posted by 83firebirdguy
those are 36#
That's what I assumed. Thanks!
Old Sep 9, 2014 | 09:12 AM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
You spent $80 at a junk yard and didn't walk away with at least half a car.
Steve78LT
Feb 24, 2016 12:15 AM
gta90
Sep 15, 2015 04:00 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Sanjay
Aug 12, 2015 03:41 PM
