1984 corvette dyno
Transmission: T-5, TH350, T-5
Re: 1984 corvette dyno
What mods have you done to it already? I like the matching red intake btw.
Must be a stingy dyno. The dyno my car was on is reportedly hard to give up numbers but I'm running iron L98 heads and unported tpi and pulled similar curves. I would figure yours would've been way ahead of mine. Or do you think your exhaust is that big of a restriction?
Granted, I don't know what your heads are capable of but looking at the cam specs I'd agree with you that it's probably too small to take advantage of those heads. It'll be interesting to see the after with new exhaust.
Car: 1987 trans am
Engine: 305ci v8
Transmission: t5
Axle/Gears: 10 bolt 3.56
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Now the heads are holding you back. You should be making well over 300whp at least at 5200
Vast improvment from the exhaust. No doubt that held you down.
But he's peaking at 4500-ish now. Sounds like the call of the LTR's. You'd know way sooner than me but I think the runner length is keeping him down. Hard to say with a FIRST though, I thought they had a higher rpm range.
The heads are Trick Flow 23 Degree 64cc and the cam is a powermax 2040 formally compucam I think with my mods that cam is to small and holding me back about 40 hp as well as a few hundred RPM
The first base flows 300cfm. The runners are 1.80 open. Those are way bigger than Edelbrock runners at 1.65.
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
the_hamturdler
Sep 30, 2015 12:50 PM
