Power Gains From Swap
Car: 87
Engine: TPI L98
Axle/Gears: stock
so i recently picked up an 87 GTA clone from a kid for a smooth $1200. Him and his father had swapped the stock 305 with an L98 block,then totally rebuilt it with new crank, rods, speedpro pistons, rings, voodoo .504 .525 with lifters, waterpump, harmonic balancer and alternator (same power steering pump) Then on budget he put some old nasty pick-n-pull heads from a 86 firebird on top of it and kept the stock TPI system. He did replace the knock sensor but having no computer or injector upgrades it ran alright for a few minutes (unbeknownst to them) they put the drivers side intake gasket on backwards so it wasnt circulating water like it should and continued to run hot after about 5-10 min, the reason they sold it. It also smoked like crazy because of the old worn out heads (which were not rated for that size cam anyway) This being my 5th third gen (4th pontiac) I couldnt pass up this diamond in the rough. I want to keep the TPI system so since then I have tore the top end off and bought brand new ported 2.02 1.60 58cc heads with .550 double springs, guideplates and screwin studs, 22#injectors, egr delete, 9th injector delete and a TB air foil. I will have sealed up this weekend, but need my compression to get new MEMCAL wrote. Will it start as is with 9th injector deleted if I flutter the TB? and honestly how do I get my compression# with the egr and 9th injector deleted??
Thanks for patience, any possible estimate on HP/TQ or compression ratio?? PLEASE HELP
Thanks for patience, any possible estimate on HP/TQ or compression ratio?? PLEASE HELP Senior Member
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: Power Gains From Swap
9th injector cars will NOT fire with out them.
Car: 89 IrocZ
Engine: L98-ish
What are you referring to as "compression"?
You have all the info in front of you to get the Compression Ratio...
easiest way to begin to start it with the CS valve plugged, use the 89 memcal, or iopen the TB a tad, shoot a shot of staring fluid in it.
Car: 87
Engine: TPI L98
Axle/Gears: stock
Im referring to having to find out my new compression ratio so I can get my memcal remapped accordingly. If that is so what do i need to do to figure it out?? thanks
Car: 87
Engine: TPI L98
Axle/Gears: stock
could i buy chance try a memcal which came stock on a 350 with teh same computer or a aftermarket memcal?? any suggestions?
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
I own an 88 with a ninth injector for nearly 25 years, I don't know that statement to be true at all. Mines been removed, deleted, unplugged since about 1995 & it never had an effect on starting. Unless I'm THE exception, someone told you wrong.
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i'm going to ask the ultimate question here.... have you confirmed that they did in fact put a 350 in it?
Car: 87
Engine: TPI L98
Axle/Gears: stock
Car: 88 IROC-Z
Car: 89 IrocZ
Engine: L98-ish
Car: 89 IrocZ
Engine: L98-ish
You could use the '89 memcal, but will have to have the VAT's deleted (I don't think your car has VAT, does it?)
Might be the simplest route to go, pretty sure your '87 uses the 165 ECM like the '89 does.
Car: 88 IROC-Z
Car: 1983 G20 Chevy
Transmission: 4L60
I have done it on 4 different TPI cars over the years and never changed any of them. 85 Corvette, 86 Camaro, 88 Firebird and a Jeep with a 87 MAF Corvette engine. Two of them are daily driven and I have not heard of any of them having issues, even on a 20*F morning.
