Only 1 bank of injectors firing
Old Sep 16, 2014 | 03:02 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I have a heavily modified 1991 350 TPI and it was running great on Saturday. Monday I popped the memcal out to adjust the startup enrichment and when I put it back in and started the car it ran and drove like crap. Barely started, had to keep on the gas.
What I thought was mechanical turned out to be none of the passenger side injectors firing. The car runs but very poorly. I ran it for 5 minutes and all 4 of the passenger side header tubes were cold. Driver side was hot.
I have re-wrote the PROM with known good working tunes onto 3 different chips with no change. I have swapped ECMs with no change.
I don't have a noid light but rigged a small bulb across the injector connector and when cranking and running the bulb doesn't light up.
Both injector 10amp fuses are good. Power to the pink/black wire at the injector.
Is it the ECM or PROM that controls injector firing? I don't have a separate complete Memcal to try right now.
Any ideas??
Old Sep 16, 2014 | 06:06 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Re: Only 1 bank of injectors firing
Probing the injector wire right from the harness at the ECM shows no grounding signal when cranking or running. How can only 1 bank be not working?
Old Sep 17, 2014 | 04:48 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
the ECM has 2 injector drivers. maybe one of them died? try another ECM and see what happens.
Old Sep 17, 2014 | 05:13 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Check the inj fuses.
Old Sep 17, 2014 | 09:00 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Found the problem. Taking the ECM out of the dash repeatadly to program the PROM caused the pink/blk injector wire to break inside the coating. Soldered it up and it works like new again.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86Firebird86
Dec 26, 2015 07:21 AM
webeeZ28
Sep 14, 2015 12:00 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Ranbo108
Sep 9, 2015 12:20 PM
