85 tpi harness adaptability
Old Oct 7, 2014 | 10:09 PM
dcd2236's Avatar
Car: 1987 trans am, 1988 Formula
Engine: 305 LG4, 305 LB9 TPI
Transmission: 700R4 in both
Is there a way to take an 85 tpi harness and adapt it for use on a later model computer? Need any thoughts to those who are good with customizing these type things.
Old Oct 8, 2014 | 11:49 AM
dcd2236's Avatar
Re: 85 tpi harness adaptability
Reason Im asking is because of my classified ad for the 85 tpi harness. Ive had 2 people ask if this harness could work in other year models but I cant give them a straight answer to be able to sell it. In my understanding the computer controls the harness and the harness is only as good as the computer plugged to it. I just need to know if an 85 harness can be modified to plug up to say an 89 or 90 computer or what steps need to be taken to get it to work.
Old Oct 9, 2014 | 10:37 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Can't specifically answer your question, as I have not done it. This link might give you some insight. It's for swapping in a newer ECM in place of an '85 ECM, so it should detail the changes required. Definitely not a plug and play swap to a newer ECM, but surely doable with some work.
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
IBrockZ
Aug 20, 2015 12:20 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
