059 vortec heads
Old Oct 27, 2014 | 08:14 PM
89blackformula's Avatar
Car: 89 firebird
Engine: LB9
059 vortec heads
Hi all,
I recently acquired some 305 059 vortec heads for my 1989 305 tpi, and have a couple questions.
1. Are the 19 lb injectors still good? Should I get an adjustable fuel pressure regulator?
2. Would be better off with an egr delete or the corvette style egr and tube?
I appreciate any input! I just want to wake up the 305 tpi, just A little, not looking for huge power gains.
Old Oct 28, 2014 | 10:11 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: 059 vortec heads
19 Lbs should be fine. EGR Delete is easier, if done in the programming. Depends on whether you need it to pass smog where you live. EGR does reduce engine temps some, so it's not an automatic decision. While you have it apart, stick in an LT1 cam- works great in the 305 and will work with the Vortec's limited lift.
Old Oct 28, 2014 | 07:53 PM
Car: 89 firebird
Engine: LB9
Thank you for the reply! I will start my quest for a cam now!
I have the cam out of the 305 vortec, but it's a marine engine. If the cam is the same as the automotive vortec, it looks to be better than my stock 305 lb9 cam.
Anybody have any thoughts?
Old Oct 29, 2014 | 10:24 AM
darbysan's Avatar
There are many different cams. You can check the one you have by measuring the total height of a lobe, and then subtract the max dia of the lobe ( Base Circle). The difference is the amount of lift ( when multiplied by 1.5). Do it for both intake and exhaust. LT1 f-body cams run in the .450-.460 range for lift. B-body LT1 cams can be more like .430 lift, but have more torque ( better for DD and stop light to stop light!).
More info:
https://www.thirdgen.org/forums/tbi/...-ultimate.html
Old Oct 29, 2014 | 10:49 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The GM "395" marine cam specs
196/206 @ .050
.431/.451"
109* LSA
106* ICL
Old Oct 29, 2014 | 11:46 AM
Car: 89 firebird
Engine: LB9
More info:
Thank you for the link! Very helpful
I think I am going to use that vortec cam...it looks as good as the lt1 cam
Thanks again!
Old Oct 29, 2014 | 11:48 AM
Car: 89 firebird
Engine: LB9
196/206 @ .050
.431/.451"
109* LSA
106* ICL
Thank you so much for the specs! I was having a hard time finding them.
It looks like I will use that cam in my lb9, and once the heads are back from the machine shop, I know my valve springs will be good with that cam.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
