need help with 1992 B4C-1LE (ALDL)
Old Nov 7, 2014 | 09:46 AM
makingPAIN's Avatar
Car: 1985 firebird
Engine: 350 .40 over
Transmission: 5 speed borg(NWC), ram clutch
Axle/Gears: ROTATING MERCURY DRIVE.
hey everyone so my dad and I are trying to set the IAC and TPS but when we go under the dash to jump the computer into diagnostic mode, the ALDL plug is missing a lot of connections. I have a factory service manual and a bunch of stuff off this site. so this is the question I need to find the color of the diagnostic wire and I think it is orange. and the ground is black with white tracer. if anyone has had this issue or can help out it would be great thank you.
Old Nov 7, 2014 | 10:19 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: need help with 1992 B4C-1LE (ALDL)
The ALDL connector is not a fully populated connector. It only has 5-6 wires, even though there are more locations available. The ones you want to jumper are the two upper right hand pins(A and B).
Old Nov 7, 2014 | 11:14 AM
makingPAIN's Avatar
Car: 1985 firebird
yeah that's the thing the second one in or (b) is hollow and in the service manual it says that its the fuel pump test circuit
Old Nov 7, 2014 | 11:54 AM
darbysan's Avatar
Your ALDL port may have been installed upside down. Mine was flipped over like that for easier access. That would put the Fuel test port in the upper right corner ( where A should be), with a blank next to it, and the A/B ports now in the lower left corner.
Here's a diagram, although it sounds like you should have this already.
https://www.google.com/url?sa=i&rct=...15469093849246
Fireslash
Apr 11, 2016 06:43 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
92projectcamaro
Sep 29, 2015 07:07 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
ironbmt
Sep 27, 2015 06:00 AM
