350 TPI issues... yet again.
Old Dec 25, 2014 | 12:43 AM
earlpote's Avatar
https://www.youtube.com/watch?v=yL7b...ature=youtu.be
A month or so ago i replaced all injectors with 22# bosch III's due to a stalling when slowing down/stopping and rough idle issue. ran great for about 50-75 miles then this new issue arose. rough idle. will usually die upon first start but on second start will stay running. sometimes will slowly die out on its own while idling. TPS is good at .54v. new IAC valve. new injectors and fuel filter. recently noticed a slight white smoke out of primarily right exhaust pipe when warmed up which you can see in video. also today i took this picture of what came out of the exhaust. after shutting engine off, smoke slowly continued to seep out of the right exhaust pipe. fuel pressure remains at about 34 psi idling.
any help would be greatly appreciated. im deploying to the middle east next month and would like to come home to a running car that i can take out, not a project to work on for the only couple months of summer ill have after deployment.
Old Dec 26, 2014 | 07:22 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 350 TPI issues... yet again.
anilize what that puddle is. if its oil, you have bigger issues. if its coolant, again, time to do engine work. man , im sorry about all this. almost enough to make a man buy a Honda!!
Old Dec 26, 2014 | 09:42 PM
chevypower91's Avatar
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
Could it be a plugged catalytic? Are you cat(s) original?
Old Dec 27, 2014 | 09:55 AM
89blues's Avatar
Car: 1989 IROC
Axle/Gears: 3:23 Torsen 4th gen rear
check your fuel pressures, my guess is a failing fuel pump or bad regulator
armybyrd
Dec 5, 2015 09:22 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
