Code 32 Code 36 Issues
Old Jan 4, 2015 | 09:19 PM
penguinpanda0's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
Working the last few codes out of my 87 305 car; the car was getting a code 32 and was running very poorly at idle, funny thing is that I put in a brand new egr valve and verified that the solenoid opened and closed with voltage. I unhooked the vacuum hose for the egr valve and the car ran great, with only my occasional code 36 issue.
The car only seems to trigger code 36 after a bit of driving. Gonna replace the connector for burn off tomorrow because the wires seem pretty loose in it. Might as well replace the relay itself too.
Anyone have any insight?
Old Jan 5, 2015 | 04:06 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Code 32 Code 36 Issues
The Code 32 can be caused bye the egr temp sensor.
http://www.zip-corvette.com/catalog/product/view/id/34239/s/86-89-egr-valve-temperature-indicator-switch-wire/category/7795/
http://www.chevythunder.com/egr_code_32.htm
http://chevythunder.com/maf_code_36.htm
Old Jan 5, 2015 | 08:39 PM
Engine: 305 LB9
Got code 44 (lean exhaust) for the first time. Any clues on that?
Cornholio7979
Sep 20, 2018 02:31 AM
777Shock777
Oct 29, 2015 04:30 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
mizz0313
Aug 12, 2015 06:45 AM
