86 Iroc won't start after running out of gas
Old Jan 27, 2015 | 01:32 AM
nathanaguirre's Avatar
Alright, so I have a 1986 Iroc z28 and when I was driving I ran out of gas. When I put gas in it, it wouldn't start, so I figured I burnt the fuel pump. I just put an Edelbrock 17933 - Fuel Pump: 255LPH in and I'm getting 45 psi to the fuel rail. When I turn the car over it sounds like it's about to start and like every 2 cranks it makes this back firing sound. I checked that I'm getting spark too and I am. I am lost of ideas of what it might be. So, I was just wondering if someone knows what the problem might be.
Old Jan 27, 2015 | 09:43 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: 86 Iroc won't start after running out of gas
Sounds like the timing is off. Running out of gas clearly wouldn't make a timing issue but from what you're describing, I'd be looking at the distributor etc.
Old Jan 27, 2015 | 10:18 AM
Yah I was thinking that too. But to be honest I have no idea how to adjust the timing aha. All I did was take the cap off and made sure my distributor rotor still spun when I cranked the engine.
Old Jan 27, 2015 | 07:59 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
["All I did was take the cap off and made sure my distributor rotor still spun when I cranked the engine."]
Was that before or after you had the starting problem??
Old Jan 27, 2015 | 08:01 PM
It was after my starting problem
Old Jan 27, 2015 | 08:30 PM
Check to see if you can turn the distributor by hand. If it moves without loosening the bolt then you found it. If it doesn't move, check to make sure your injectors are being told to spray by the computer. A test light or nord light is needed. If those check out, there is the possibility the timing chain jumped as it sounds like timing is off. It's not very likely to be the chain.
But it could be something completely different, won't know without more troubleshooting and information.
Old Jan 28, 2015 | 08:56 PM
So my distributor doesn't move, but however my distributor rotor seems to fell lose like it has a little bit of play in it. I don't know if that's a problem. I was going to set it to top dead tomorrow and see if the rotor is pointing at the number one spark. I didn't get a chance to check the fuel injectors.
Old Jan 28, 2015 | 09:30 PM
Check your plugs too. See what they look like. Dry? Wet? Old? Worn?
Old Jan 28, 2015 | 09:34 PM
My plugs are new, but my old ones were a little wet not like terrible, just a little bit on the tips.
Frozer!!!
Jan 19, 2024 04:55 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
mustangman65_79
Aug 11, 2015 03:17 PM
