TPI setup different than most
Old Feb 5, 2015 | 01:32 PM
Wild 90's Avatar
Car: Frame chopped '98 chevy k2500
Transmission: nv4500
Axle/Gears: 14b ff 4.10
Anyone ever seen one of these before?? or know how it would preform?? Looks like if you added some injector holes you could use any 4bbl intake you wanted. Anyone know where you may be able to get one?
Old Feb 5, 2015 | 02:36 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: TPI setup different than most
Wasn't that a custom made piece from the C4 vet forum? There are quite a few of these floating around. Not all look like this though.
Kinda like installing a mini ram
Old Feb 5, 2015 | 03:01 PM
Wild 90's Avatar
Guy posted some pics up of it on FB. Claims its good for 700 hp with a 58mm TB on it. Not sure i believe that but may be worth a shot fabbing one up. I got a spare 4bbl intake laying around. May build one and slap on the 87 and see what happens. Wouldn cost anything but some intake gaskets.
Old Feb 5, 2015 | 04:59 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by Wild 90
Guy posted some pics up of it on FB. Claims its good for 700 hp with a 58mm TB on it. Not sure i believe that...
He means it will support up to, and there are too many variables to say yay or nay. I don't see why it wouldn't, so long as it is ported properly, heads flow excellent, and cam is good for well over 6000+RPM, it's just a matter of engine displacement then...
Old Feb 8, 2015 | 09:20 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Thats not your typical intake with direct injection ports
Old Feb 9, 2015 | 12:20 AM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Manifold looks similar to a speed master?
stalkier
Dec 6, 2015 11:25 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
