New distributor rotor burnt
Old Feb 12, 2015 | 03:56 PM
214jay's Avatar
Car: 1989 Pontiac Firebird Formula 350
Hello. I have recently got my car back together after head gasket change and replacing all of the ignition components.
I have been having some running issues and there are a number of dead spots whilst driving and badly backfires through the exhaust. Timing has been set a 6* So that's okay.
I took the dizzy off today to find the rotor is slightly burnt And has melted the plastic on the side. Not sure if this is related to my issued, have changed the dizzy and rotor for a new one today but still same faults. Has anyone experienced this problem?
Thanks. J
Old Feb 12, 2015 | 05:10 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Re: New distributor rotor burnt
This happened to me on a much larger scale. Rotor and where it meets cap melted right through. I later found low voltage rotted / loose wires into and around the coil and dist. One wire to the coil was being held together just by the insulation. I think coil fire signals were showing up at the wrong time in the cap and created a firestorm in there.
Old Feb 13, 2015 | 12:07 AM
214jay's Avatar
Oh that's interesting, I will inspect the wiring around that area. Did you get any adverse symptoms as a result of this?
Old Feb 13, 2015 | 01:54 PM
TallTim's Avatar
The engine was working up to the point where I went to remove the coil wire from the dist and it came off with the terminal. Surprise!
http://i1072.photobucket.com/albums/...pse50e042a.jpg
Old Feb 13, 2015 | 03:17 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
GOOD LORD!!!!!!!!
Yeah, you found it alright!
MM2Robinson
Oct 1, 2017 09:16 AM
camarohelp
Sep 22, 2015 03:19 PM
BLK87Z
Sep 18, 2015 11:29 PM
m00n420
Sep 11, 2015 02:39 PM
Jlanz55
Sep 6, 2015 03:05 PM
