Forgot to put this back during fuel pump change, will it cause problems?
Old Mar 29, 2015 | 01:29 PM
Slowridr's Avatar
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
This is a 91 TPI 5spd GTA
Noticed this after I was finished with the fuel pump change out. This little white colored disc was between the strainer and the bottom of fuel pump. Not quite sure what its purpose was. I didn't want to have to take the fuel pump out again so I went on.
The car surges/bucks when driving it. It does it in spells but does it pretty much every time I run thru the gears. Along with the fuel pump I changed the fuel filter. I also checked the injectors and they all ohm out at 17.
What I fear is that I am going to have pull the fuel tank and get it cleaned out. I am betting that it has trash in it. I got to this point because someone ran my car out of gas and burned the pump out. My convertible had the same issue and I changed the fuel pump, fuel filter, fuel pressure regulator, and it didn't fix my problem. Once I had my tank cleaned it has run smoothly ever since.
Before I pull the tank to get it cleaned I want to know if there is anything else I can check.
Attached Thumbnails Forgot to put this back during fuel pump change, will it cause problems?-fuel-pump-piece.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
