305 TPI Problems
Old Apr 5, 2015 | 06:56 PM
greggie82's Avatar
Car: '91 Z28
Axle/Gears: 10 bolt Posi 3.23
305 TPI Problems
Hey guys I am having a few problems with my 91 z28 305tpi.
I keep having issues with the Fuel Pump going bad I have tried different brands of pumps as well changed the Sending Unit and checked the Ground but still having the issue I have replaced fuel pumps 6 times in 2 yrs so far and think my current pump that is only a couple months old is starting to have the same issue again.
As well after changing the pump this past time I decided to go with the Performance Pump with a higher PSI Output of 65psi so the pump would have to cycle les to keep the 35-43psi at the rail.
But since this pump change I am now getting a lot of noise from the Injectors when the car is at idle you can hear them pulse slightly but when accelerating the Pulsing Noise gets much louder and can be heard inside the car over the exhaust noise.
Could the injectors be going bad or the Fuel Regulator be allowing too much pressure in the rail?
I am unable to test the fuel pressure at the rail right now but will be installing a Pressure Gauge soon.
Any thoughts on these issues are greatly welcomed.
Old Apr 8, 2015 | 09:44 AM
Mike 92LX's Avatar
Re: 305 TPI Problems
Are you running the car on or close to empty often? The fuel acts as a coolant to the pump. Low fuel levels can actually damage it
Old Apr 8, 2015 | 09:47 AM
keykey's Avatar
Car: 1988 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH700R4
Axle/Gears: 3.27 9-bolt w/ Torsen LSD
If you have changed the pump 6 times, you are either incredibly unlucky with bad parts (not very likely to get a bad pump 5 times) or something else is causing the problem.
A couple of questions:
What is the problem that makes you replace the pump? Is it just noise from the injectors or is it a no-start-situation because the pump stops running?
Have you replaced the fuel filter?
Have you replaced the pump strainer/screen?
Have you checked the tank for contamination?
Have you checked the fuel tank ventilation?
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
