TPI IAC pigtail / parts... Disassemble ?
Old Apr 7, 2015 | 09:41 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Was working on my TPI throttle body the other day an noticed my IAC plug clip is broken...
Checked Ebay and saw they sell complete pigtails and one as parts...
Is there a way to "dissasemble" mine, and just replace the housing, and rebuild it? I don't want to cut / solder wires, or crimp existing short wires...
I know with some plugs and stuff you can use a tool to disassemble, etc...
& I already asked the seller, he was not sure...
Here is the plug in parts...
http://www.ebay.com/itm/171438905708?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Raf
Old Apr 7, 2015 | 09:56 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI IAC pigtail / parts... Disassemble ?
http://m.ebay.com/itm/390970267954?nav=SEARCHOr
http://m.ebay.com/itm/370504592169?nav=SEARCH
Old Apr 7, 2015 | 10:04 AM
luvofjah's Avatar
Thanks!
Don't want the plug to come undone while I'm passing some Mustang
Rafael
Old Apr 7, 2015 | 12:50 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Save yourself the hassle and get the tools posted above. They pop in and out. Like a 2 min job.
Old Apr 7, 2015 | 02:21 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
I just did this with the IAC and TPS connectors. Real simple, just make sure to keep track of which wire goes where by either doing it one at a time or taking a photo (or both). As long as the terminals are in good shape (which they should be if the weather pack connector was doing it's job) there's no crimping required. My connectors were literally falling apart as I tried to take them off; 20 years of heating and cooling makes the plastic extremely brittle.
For anyone having TPS or IAC connectors broken, go this route. It's much easier to order the weather pack housing with pin removal tool and swap the terminals over than trying to crimp/solder in a pigtail.
Old Apr 7, 2015 | 06:06 PM
SailorMoonElite's Avatar
Car: 1991 RS (sold), 1991 Z28
Engine: LO3, L98
Transmission: T5, 700r4
Axle/Gears: 2.73, 3.23
This was literally the first thing I did when I got my car because the IAC housing was broken. I ordered just the actual housing itself (black part) and pulled the wires out of the 4 holes and plugged them in accordingly with the new one. You have to "unclip" the old wires and plug them into the new ones. You won't have to cut anything. I didn't want to either. The IAC housing only costs me like $6 (december 2014)
stalkier
Dec 6, 2015 11:25 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
