1986 Iroc z28 ran out of gas and won't start now
Old Apr 30, 2015 | 12:08 AM
nathanaguirre's Avatar
Alright, so my Iroc ran out of gas and it wouldn't start after. So I figured I blew the fuel pump and I replaced it with a Walbro 255 and now I have enough psi in the fuel rail. So I figured it was th e timing because the car sounds like it's about to start, but then it back fires. So today I check the timing, and the TDC marks line up on the chain. It also has a double roller so no way in hell it's the chain anymore aha. The rotor on the distributor is pointing at spark 1 too. So now I have no idea what the problem is.... I've replaced the sparks and wires too. Could the injectors be clogged? One the bright side now I can install a bigger cam, water pump, and fix my oil leak from my timing cover aha so yay on that!
Old Apr 30, 2015 | 05:41 PM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
Re: 1986 Iroc z28 ran out of gas and won't start now
What about spark? Bad ignition module possibly?
Old Apr 30, 2015 | 06:18 PM
I'm getting spark too, I'm thinking maybe my fuel injectors are clogged up or something.
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
jklein337
Sep 19, 2018 06:23 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
