Rough Idle When Cold Need TPI Help!
Car: 1987 Pontiac GTA
Engine: ZZ4 350 W/ HSR
Axle/Gears: 9 Bolt 3:45
Hello Everyone,
I recently purchased a 87 GTA 305 TPI 5-speed from a local auction. The car was not in running condition when I got it. I found out that all that was wrong was the fuel pump. Once I changed the fuel pump it fired right up. The smell of the gas fumes were horrible and I could tell that this car had been sitting for a long time. It will not hold an idle when I start the car, if i hold my foot on the pedal and let it warm up it will purr at 900-1000 rpms. My other f-body is a carbureted car so im new to this TPI stuff. Any one out there able to help?
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Re: Rough Idle When Cold Need TPI Help!
If it's been sitting for a while, it could be a lot of things. The first thing I would suspect is that the injectors may be clogged up or sticking. I would also check for cracked or loose vacuum hoses. If you do a search here for "rough idle" you'll find a lot of past discussions on the causes and fixes for the problem.
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Put some new gas "premium." A quick tune up; plugs, wires, distributor cap, change the oil and coolant flush. Then go from there.
Thanks guys. I have changed the plugs and that seemed to clean up the miss but not the rough idle. I will get some new high test gas and put some fuel injector cleaner in the tank and see if that cleans it up.
Car: 89 Black GTA
Engine: 'close to' stock 5.7 but trending>>
Transmission: 700
if you can hold the idle with your foot, try adjusting the TPS. Also, i'm not sure if you have a Cold Start Injector, but if you do, search for topics covering that thing.
Now when it comes to adjusting a Carb im fine, but you suggested adjusting the TPS. How do you adjust the TPS. Also it holds a good idle where it should once its warm so if I adjust the TPS wouldnt it screw up once its warm and be too high?
Engine: 5.7L TPI
There is a tech article about it here:
https://www.thirdgen.org/tpimod2
If you do a search here on "tune up", "idle adjustment", and such you can find a lot of past discussion on the topic.
Car: 1987 Trans Am
I am having a similar problem and found a kit to delete the 9th injector all together. Won't doing that make it impossible to start normally?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
if you delete the ninth injector enrichment you will need to have your memcal reprogramed to 89 tpi maf $6e mask.
Car: 1987 Trans Am
Being new to fuel injection mods where can I find out about learning to burn my own proms and make modifications to the computer when I put engine upgrades in?
thanks
thanks
Engine: Lb9
Transmission: M20
Read the stickies in the DIY prom section or contact me for reprograming
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
i know this is an old one, but ... from what i have read, the cold start injector has nothing to do with the cold idle, and only comes on when the key is in the start position under 95 deg ... i am also having this cold idle trouble, did it ever get fixed, and if so what was it
Barlow8869, No I never did completely fix this problem. as mentioned at first in this thread, I just did your routine tune up (plugs, wires, air filter, cap/rotor, fresh gas w/additive) and it cleaned up most of it.
The only reason i haven't went crazy and made sure everything was perfect is, I plan on doing a motor swap this summer rather put my money into getting things I need for that.
Sorry I couldnt be more help, best of luck though!
Sanjay
Aug 12, 2015 03:41 PM
